If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
would like to know the proper way to clean an aluminum intake manifold. not sure if I could bead blast with 170-320 beads, or it should be cleaned up with a high preassure washer with an industrial type soap.any response would be helpful. Henry #38383
There are restoration companies out there that can make it look brand new. I used strong degreaser and painted mine with engine spray paint (aluminum).
I have heard bead blasting is the way to go, but haven't tried it on aluminum yet.
If your goal is to NCRS restore the intake, DO NOT BEAD BLAST IT! You will end up having to later pay someone to "reskin" it. You can safely use aluminum wheel cleaner or aluminum safe aircraft paint stripper.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
