Carbon steel exhaust supplier - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    For anyone interested, Corvette Central will supply original style, carbon steel systems. (same price as aluminized)
  • steve wallach
    Re: Carbon steel exhaust supplier
    For C3s also? Original style?
    Steve
    • Rob A.
      • December 1, 1991
      • 2126
      Steve,
      I think for any system they normally do in the aluminized. They said they need a couple of weeks notice.
      • Steve Wallach
        Do you have contact numbers and the name of who I should speak with?
        Thanks again,
        Steve
        • Rob A.
          • December 1, 1991
          • 2126
          I just talked with Corvette Central tech support.
            • 11608
            Realize that while you are getting carbon steel pipes, they are NOT shaped and bent "exactly" like the ones originally installed on your car. So, you will gain a couple of points by not having aluminized pipes but may still lose for the shape of the pipes themselves.
            Just trying to inform...
            FYI, I'd use something like PreLube 6 on them to keep them from rusting.
            Patrick
            • Rob A.
              • December 1, 1991
              • 2126
              Patrick,
              Is there a supplier that has pipes that won't receieve a deduction for shape, bends, etc?
              • Kevin M.
                • November 1, 2000
                • 1271
                • Dick W.
                  • 10483
                  There is a vendor that is working on a limited number of pipes. He claims to have the pipes done, but his mufflers will not have the "W" as original. I do not know what time frame he is working with.
                  Dick Whittington
                  • Rob A.
                    • December 1, 1991
                    • 2126
                    Re: No
                    I'm confused, I thought the standard undercar exhaust on mid-years was two pieces. The second being welded to the muffler.
                    • Kevin M.
                      • November 1, 2000
                      • 1271
                      Rob,
                      I count the down pipe from the exhaust as one, then from factory, the second is the pipe with muffler attached. 3 pieces would be the separate muffler.
                      Dick, my original factory muffler has only the A for Arvin are we sure that all mufflers from the factory had GM and parts numbers on them? or W?
                      Kevin
                      • Dick W.
                        • 10483
                        Arvin was another OEM supplier. Vendor mufflers will not have any logo
                        Dick Whittington
