Ok, I have sorted my starter out but I have a wire that does not fit the wire diagrams. At the starter I have the Black battery cable, the red harness wire, and the red wire on the small terminal. Then the wire diagram shows a yellow wire for the coil terminal, but I only have a thin redish wire left, no yellow. The redish wire does seem to run to the area of the coil. What is it, and why no yellow. This is what I am sorting out. My 1972 convertible is a base engine car. I will be using it as a accasional fair weather driver, but I am putting it back to original. The previous owner put in a 75 engine, HEI and replaced the speedo and tack with the 75 units, I am putting the original distributor and gauges and engine back, all else seems to be there. I do not think the harness was changed although it apears they added wires.
cal
cal
