wiring problemon gauges - NCRS Discussion Boards
  • John O.
    • May 31, 1998
    • 480
    Hi
    I purchased a wire harness for my 1962 corvette from Lectric Limited. Installed it and everything works but I seem to have one problem.I followed their diagram. The gas gauge does not move and the Amp ( Battery) meter bounces around. Could the problem be that the diagram is wrong and the wires on those two gauges need to be reversed? I could really use some help here.
    Thanks..........John
  • Roy B.
    • February 1, 1975
    • 7044
    Re: wiring problemon gauges
    Bad ground?? at tank and engine??
    • John O.
      • May 31, 1998
      • 480
      Hi Roy.
      I did a complete frame off restoration and installed a new tank and wiring harness.I'm grounded ok. Someone mentioned awhile ago about the lectric limited wiring diagram being wrong and he had a similar problem. Would you know anything about this? Is there any easy way to test this? If I were to switch the wires between the fuel gauge and battery gauge could it do harm to the gauges if that was not the problem ? I'm thinking it might be the problem because right now the Battery gauge is jumping when I start the engine and the gas gauge stays at empty.
      Any help is appreciated.........Thanks.....John
      • Donald L.
        • September 30, 1998
        • 461
        Just look under my 62.
        Amp Gauge driver side terminal - black wire & radio cap
        passenger side- 4 red wires
        Fuel gauge driver side- pink wire
        passenger side - brown wire
        • Bruce Boatner
          John,
          Why not just move the amp wire to the fuel gauge and leave the amp gauge disconnected and see what happens? I've heard the amp gauge is delicate but I doubt you would damage the fuel gauge with a wire intended for the amp gauge.
          • John O.
            • May 31, 1998
            • 480
            Thanks Bruce and Don
            I am going to try to switch the wires and see if that works. I heard from a few people that the Lectric Limited wire diagram was wrong.
            Thanks....John
