Exactly what makes the off-road exhaust system different than the standard under car system?
'66 off-road exhaust system distinction
Re: '66 off-road exhaust system distinction
Rob,
The "off road" exhaust system looked nearly identical to a standard system but there were some changes inside the mufflers. There were less baffles and, if I remember correctly, the remaining baffles had larger holes. Beautiful music came out of those mufflers, especially when coupled with any engine 340 HP and up. Discontinued about fifteen years ago.- Top
-------Mike is correct in all respects. As well, I believe that the off-road muffler is a bit smaller in circumfrence. At least, when ever I installed a set there seemed to be more clearance between the muffler and the lower edge of the rear outer fender, just forward of the rear exhaust filler panel........Bill S- Top
Kevin, Bill, Michael, and Rob------
All N-11 off-road systems used 2-1/2" exhaust pipes (outlet pipes were the same as standard mufflers at 2", though).
The N-11 mufflers were identical to standard mufflers with respect to external dimensions and configuration----17" in overall length and 24" in circumference.
The difference between standard and off-road mufflers internally involved the number of tubular baffles----standard mufflers have 3 baffles and off-road has 2.In Appreciation of John Hinckley- Top
Bill,
Another absolutely amazing thing about this system is their life expectancy. I installed a new set of "off roads" on my 66 in fall of 1983 and their STILL on the car. Probably have 30,000 miles on the car since then and they still look fair. The pipes were made nearly twice as thick as auto parts pipes.
I do have the heat riser disabled and open though and I know that helps extend the life of the right side.- Top
Kevin,
That's wild. Almost 40 years old and still going. I thought I was doing well at 23 years. Imagine if there was never a heat riser, the right side might also be the original.- Top
