C3 ? on trailing arms Insall before or after - - NCRS Discussion Boards
  • Rob C.
    • August 31, 2004
    • 144
    Black out and was the under coating installed before or after black out.
    Thank you in advance.
    Rob
  • Michael H.
    • January 29, 2008
    • 7477
    Re: C3 ? on trailing arms Insall before or after -
    Rob,
    Chassis blackout, what little there was for C3, was performed with the chassis complete and just minutes away from body drop. Basically, the only item that received a direct hit of blackout in the area of the rear control arms would have been any overspray from muffler blackout so the control arms most likely would have received near zero.
    The undercoating process for wheel wells was performed hours before the body was anywhere near the chassis so there would be no undercoating, at all, on any chassis components. Hope this helps.
    • Rob C.
      • August 31, 2004
      • 144
      Michael,
      Thank you that helps a lot.
      Rob
