C2 BB Fan Blade
Re: Rocket Science.
Having taken Mikie's advice (well before he gave it)I might be more off balance then the fan. How could you achieve balance With 5 blades that are not positioned semetrically? The blades aren't even positioned equally around the center. Unlike the mass on a drive shaft or wheel, the weight of the 5 blades aren't even close to being positioned 72 degrees apart.(360 / 5)
or, what am I missing?
Larry- Top
Re: Measuring the diameter of fans can be tricky..
hey tc: its 8 am, read am, here in mary's land and although i don't usually visit the Beast's refrigerated lair till the evening hours, after reading your disertation(only got half way thru it), its Miller time hereabouts. mikie- Top
truly sorry about this Mike... I don't do this very often but when it happens it's kind of like watching a cat cough up a hairball. If I were there with you to draw a few pictures in support of the whole thing it would be much easier to follow. It's important to note that I AM NOT advocating that we try to "balance" one of these fans. I do not think it is possible anyway with the blade placment as it is.
Anyway, if you started with the beast at 8:00 this morning you may be in the right frame of mind by now to understand my previous post. Read it again if you dare....
tc- Top
