As I read it, on a 327/350 HP 1968 the judging manual says there should be a cast iron thermo gooseneck, The manual also says there should be a front lifting hook on the second bolt back, drivers side. If you have both, the upper radiator hose doesn't clear the lifting hook.
Anyone have an original 327/350 HP with the correct thermo cover and lifting hook? Could you e-mail me a picture?
Thanks, John
Thanks, John
