1) I have a '64 roadster w/ Powerglide and would like to change the transmission oil/fluid. The original service manual recommends a "Type A" variety; the guy at the local auto parts stores recommends Dextron 3. Which one should be used?
2) In changing the fluid, are there additional steps that I should be aware of other than draining the fluid, dropping the the transmission pan and cleaning the screen?
2) I am replacing the original rubber lines up to the cooler. How much transmission fluid do I need to do the entire job?
3) I bought a transmission drain plug from L.I. Corvette with a magnetic tip that would, supposedly, catch the metal particulates circulating in the transmission oil. It looks like a pipe plug rather than the original-looking drain plug. Does it make sense to use this magnetic plug and sacrifice the original look?
