Hello All,
I spent a lot of the day in the garage working on Dad's 72, and unfortunately have a new problem.
The original upper dash pad was severely cracked, so I replaced it with an Al Knoch piece. No problem, and I also reinstalled the two original dash "pods" containing the speedo/tach as well as the map pocket.
The problem I now have is this: I do not seem to have enough room between the "pods" to reinstall the center gauge cluster. There is plenty of room for most of it, but the top 3-4" (vertically) seems too narrow. I have loosened the pods from the dash pad, but still I am not able to insert the gauge cluster in place. As the cluster housing is $160 to replace, and easy to break, I am not forcing it. I have used my old broken cluster piece to try and work out a solution, but without success.
Reinstalling the cluster is something I have done several (?) times on my 71 without fail, so all I can think of is that the new upper dash pad has positioned the "pods" about 1/8" too close together to allow the center gauges to fit.
Has anyone else had this problem before? Any suggestions? Taking out the pods and reinstalling is NOT my favorite Corvette activity, but I am open for suggestions.
Thanks in advance,
Patrick
Thanks in advance,
Patrick
