I recently purchased a 04 Commemorative Edition which was prevoiusly a California car. As a result it has no Front License Plate Cover. Of coures the cover should be Le Mans Blue. Does anyone happen to know were I might locate one. Of course they are Available from the dealer however, I would rather have a original.
License Plate Cover
Re: License Plate Cover
Frank and George-----
The one George mentioned will be identical to the original, so there is no problem there. However, as mentioned, it will not be painted the correct color. You'd be better off all the way around if you could find one correctly painted. I'd try some of the larger late model Corvette salvage yards. Steve Arcoleo in NY is one that comes to mind. You can reach them at 718-331-0456.
If you go to a show like Carlisle, you'd probably have no trouble finding one just like you need.In Appreciation of John Hinckley- Top
