Oil Pan 1967 327/350 - NCRS Discussion Boards
  • Joel T.
    • April 30, 2005
    • 765
    I am trying to sell an extra 5 Qt oil pan on e-Bay nd have some guy asking me if it will fit his '67 327/350. It is correct for my '63 327/340 but I have no idea if it is correct for his application. The guy wants pictures and measurements which I will do, but thought you folks might know what is correct for his particular application.
    Thx,
    Joel
  • Scott Marzahl
    Re: Oil Pan 1967 327/350
    This is the large pan correct, it will fit unless he has power steering. My '67 L79 had one it but then I added P/S and went with the Z-28 pan.
      Joel-----
      No 1967 Corvette with small block was ever ORIGINALLY built with the pan you describe (either GM #3820001 or GM #359942). However, as Scott mentioned, this pan will FIT a 1967 small block unless that car has power steering. So, while the pan will FIT, it would not be CORRECT for any 1967 Corvette small block.
        • 15610
        Also, the manual steering damper will not fit on "big" pan engines - L-76 and L-84, in which case Chevrolet just didn't install the damper.
        • Joel T.
          • April 30, 2005
          • 765
          As always guys, thanks for you help!! Joel
