If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
if old bubba, who installed the t-10, didn't modify/remove the 54 style shifter area of the tunnel, you'll not have a big problem . i suspect the t10 4 speed hole cut in your floorpan is far enough removed from the original 54 shifter location that simply filling bubba's hole wigood luck, miketh resin and cloth will solve your problem.
Thanks Mike and Wayne. Bubba also added a blow proof bell housing to the car, and I suspect that he enlarged the whole hump to accomodate the larger bellhousing. Oh well, no one said that this would be easy!
if you have to replace the tranny tunnel, i'd look around for a used oriiginal. 54 carcusses show up at carlisle on occassion. also suggest ya put an ad in the driveline.mike
Joe, I have the same problem with a '55 I'm putting back together, I believe Corvette America carries a replacement trans hump, goes for around $160.00.
Mine is not too butchered, I have a '54 at the National Auto Museum that I can inspect and take measurements from....
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
