trouble shooting c1 windshield washer - NCRS Discussion Boards
  • Calvin C.
    • May 31, 2002
    • 240
    What is the proceedure to to touble shoot a winshield washer on a 58-62 c1.
    thanks
    cal
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: trouble shooting c1 windshield washer
    Make sure the vacuum hoses are correctly attached. This is a common problem.
    • Mike E.
      • February 28, 1975
      • 5134
      Second step, after checking the hoses for routing, is to send it to Tom Maxwell to have it fixed. (only halfway kidding) Rubber inside dries up and lack of vacuum no longer allows things to work.
      • Rob Edwards
        Mike-
        That begs the question: (since Tom rebuilt our washer pump last year and it's been in dry storage since) Once you have the system working, do you keep the reservoir full of water, or dry? The wiper system will probably never be used other than for PV, given the $50 set of wiper blades on the car, and being driven less than 2000 miles/yr in sunny SoCal. I wonder which method will cause the system to re-degenerate more slowly?
        • Mike E.
          • February 28, 1975
          • 5134
          Rob--
          I used to live in El Cajon, so I remember so cal well. It was always a challenge to remain hydrated there--and I believe that that is important for the washer system as well. Some guys I know remove the wiper arms and actuate the system every once in a while to keep it fresh. Tom M. would, I'm sure, have an opinion on the value of doing that--I don't know if his would be the same as mine.
          Mike
