I have a 4 core Harrison radiator in my 67 BB A/C car with the MK tag and what looks to be a 007213 number on a brass tag. Any one know what this number is and is this where the part number is?? Thanks Larry
67 radiator number
Re: 67 radiator number
larry-----
Generally, the "MK" code refers to 69 and later radiators. However, it may have been used for earlier radiators, too; I'm not sure. Your application would have used radiator GM #3008567 if a manual transmission and GM #3008566 if Powerglide-equipped. A lot of times, these numbers will not be found on the radiator. If present, they'll usually be on a tag soldered to the passenger side tank.In Appreciation of John Hinckley- Top
