C2 Soft Top Window Cleaning - NCRS Discussion Boards
  • Alan Drake
    Would like to clean (buff) my 1964 original rear window on the soft top. Has the past ten years resulted in a good method to take out the small marks? What is the best product to use, to make window look new?
    AND I'm missing the rear window tag - anyone selling a replacement?
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1464
    Re: C2 Soft Top Window Cleaning
    Megeuiar's (sp?) "Mirror Glaze" in the blue plastic bottle. The only thing!
    Available at all auto supply stores.
    Put a drop or two on a cloth and rub in circular motions over a small area until it is gone. Support the window from begin. Takes out all the small scratches and spiderwebs. Works on the hardtop and all plexiglas as well.
    Greater clarity with each application.
    The tags are available through all of the Corvette parts suppliers.
    H. a. N. D.
      Meguiar's also sells a pair of two-step products made specifically for renewing plastic convertible windows - check their website (www.meguiars.com).
      Meguiar's
      • Michael D.
        • February 1, 1978
        • 159
        There is a product that many marine canvas shops use. Its called "210 plastic window scratch remover and polish" it works really well on plastic boat windows, We use it on conv. windows as well.
        • Roy B.
          • February 1, 1975
          • 7044
          For minor scratches use 3M Foam Polishing Pad Glaze -05995 hand pressure removes most and cleans it.
            There are also several products from Novus that are made specifically for aircraft windshields - you might find them at a local FBO or from Aircraft Spruce.
