1958-62 heater switch resistor - NCRS Discussion Boards
  • John S.
    • July 31, 1990
    • 292
    Can I go to Radio Shack and get a new resistor for the heater switch? If so what I'm I looking for. thanks john
  • David B.
    • July 31, 2004
    • 330
    Re: 1958-62 heater switch resistor
    John,
    A '57 resistor should be 15 ohms - don't know if 58-62 is the same (see NCRS message #18122). The required resistor must be wirewound. Radio Shack does not carry anything close in the stores that is capable of handling the wattage (hp) required at that resistance. I am getting ready to experiment with 2 @ 8 ohms in series. It will double the power carrying capability (30 watts), plus the resistance. If I find a more suitable resistor, I will change it over later. Here is a link for the ones I am using. Since I had to buy 25 of them (!), I wouldnt mind sending a couple to you if you wish.
    David
    Dave, 1969 427, 1957
    Previous: 1968 427, 1973 454
