Hello all,
I'm trying to get the windshield washers to work on my '74.
I have removed and inspected the valves and o-rings in the white plactic assembly atttached to the wiper motor. I primed the pump and blew on the hose until water came out of the jets on the wiper arms. I re-primed the pump, started the wipers and activated the pump, still does not work. When I push the washer switch I can hear the pump kick in but about once each full revolution of the wiper motor there is a snapping noise. This only happens when the pump is activated. I'm wondering if the connecting rod on the pump piston is broken.
How do I get to the mechanical part of the pump to check it out? I've looked in my catalogs and it seems like the '74 pump is unique and I can't find any repair parts other than o-rings. Will the wiper motor have to be rebuilt just to fix the pump? Thanks in advance for any help. Bill
