Using the Keith Black software (http://kb-silvolite.com/calc.php?action=comp) to compute static and dynamic compression ratios and am confused by a rquired entry field.
"Intake Closing Point (degrees)ABDC @ 0.050 lift plus 15 degrees".
I am using a 929 cam with the following specs... Duration 195/202 degrees, LCL = 112 degrees, and .390/.410 lift. Where would I get the intake closing point (.050 lift) ABDC for this or any cam?
The old gray matter can't seem to get a grip on this one..
JimV
JimV
