Air compressor lines - NCRS Discussion Boards
  • Peter J.
    • September 30, 1994
    • 586
    When you gentleman with home shops hooked up your air compressors did anyone use galvanized pipes and if you did, did you have any trouble with galvanization coming off the inside of the pipes. Just bought a TP Tools blast cabinet and saw in the fine print not to use anything but black iron pipe.
    Thanks for your time,
    Pete #25176
  • Kent K.
    • December 1, 1982
    • 1139
    Re: Air compressor lines
    Pete ---- installed copper water piping for my garage/shop compressed air piping.
    Kent #6201
    Kent
    NCM Founder - Member #718
    • Gary C.
      Administrator
      • October 1, 1982
      • 17549
      Black iron pipe is least cost & easiest to do *NM*
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Mike M.
        • May 31, 1974
        • 8365
        agree with gary. my first shop utilized PVC. blew one nite. second shop, now 25 yrs old, has black iron and i've had no troubles with it. mike
        • Jim L.
          • December 1, 1981
          • 50
          Pete
          Any compressed air or gas line can never use galvinized pipe. The flow of compressed air thru the walls of the pipe create a ripping on the walls of the pipe causing the galvinize to break off small particles. Best use is copper or black iron or SS.
          Good Luck
          • Peter J.
            • 586
            Thanks guys, I looked at the prices TP Tools was getting for their pipe kits and went to my local hardware and could assemble the system for half the cost if I did myself even in galvanized pipe. When I got home I saw the fine print note about black pipe only. If I had not pulled my back out two weeks ago, I would be looking at completed system with all galvanised piping. Thanks for the advice,
            Pete #25176
            • Dick W.
              • 10483
              Pete, check with Mike Cranford. He has plastic line kits. Very easy to install
              mike427cranford@aol.com
              Dick Whittington
              • Louis Kolb
                Pete,
                Mike Cranford is your best bet. He does air compressors and related equipment for a living.
