C2 Transmission Number Help - NCRS Discussion Boards
  • Alan Drake
    Need to verify and photo all numbers that may be on my 1964 transmission. However I'm not sure where they are all at. Is there a date code?
    The pass side has 3851325 on it with Pat# 3088336.
    The shifter cover is 3831707
    Driver side on case next to tail shaft small # 4113901
    Front round cover has a number on it, not sure.
    Does tail shaft have a number??
  • Wayne M.
    • March 1, 1980
    • 6414
    The other numbers
    Tailhousing on driver side, halfway to main case ... number should end in ...429 on a raised boss (maybe upside down) . Assembly date: driver side shifter cover, lower right corner on maincase (machined flat surface) will probably have P0317 (example). Front bearing retainer that you refer to probably has number 3851326 cast into.
    I think that's about it, including the numbers you have already found.
