Casting numbers on Rear Differential - NCRS Discussion Boards
  • Tony H.
    • May 31, 1993
    • 537
    Did the casting numbers on rear differentials change between 1967 and 1979? How about date formats in those years?
    Tony
    Re: Casting numbers on Rear Differential
    Tony -
    '67-'75 diff castings were #3899143; not sure about after that.
    • Tony H.
      • May 31, 1993
      • 537
      Thanks John, I was not sure after 72. So, that helps. Any info on the casting date changes in that time period?
      Tony
        Tony-----
        Casting GM #3899143 was used for Corvette from 1967 right through 1979, the last year for a cast-iron housing on a Corvette. There were no changes that I'm aware of in date coding. However, some of these housings have been seen without date coding. I don't know when these were produced (obviously).
