'66 seat track lubrication - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I took the seats out of my '66 to lubricate the tracks. Can anyone recommend a good cleaning and lubricating process? It doesn't seem that easy to get the lubrication where I think it needs to go. I don't want to use WD40 or anything that will leave an odor.
  • Bill W.
    • November 1, 1977
    • 402
    Re: '66 seat track lubrication
    Howdy Rob,
    If your seat covers are still on the frames, protect them. Most cleaners won't do them any good. We used Berrymans B-12 carb cleaner with good results on the tracks in my '66. For lubrication, "lubriplate" worked fine. I wouldn't use chassis grease, it will dry and harden. If you turn the seats upside down and use a hair dryer to warm the metal, then work the tracks back and forth while applying the lubliplate, you should be happy with the results. Bill
    • Rob A.
      • December 1, 1991
      • 2126
      Bill,
      The seat covers are still on. I'll try your cleaning method. Can lubriplate be found at Pep Boys, etc.?
      • Bill W.
        • November 1, 1977
        • 402
        Rob, Yes, it's widely available in both spray can or squeeze tube. Bill
        • Stephen L.
          • May 31, 1984
          • 3148
          Why don't you take the tracks off the seats and then you can clean them any way you want. Just 4 bolts per seat. I cleaned mine and then used Ultra Flat Olive drab krylon paint. Came out very close to original. Most of original finish was gone....
          • John O.
            • May 31, 1998
            • 480
            Hi Rob
            What Steve said about removing the tracks is the best way so you don't get an odor on the seats and you can clean them good. I would recommend White Lithium Grease. It comes in a Spray Can and can be purchased at any automotive store. I'm using it on my tracks.
            John
            • Rob A.
              • December 1, 1991
              • 2126
              Thanks for all the replies....
              ...I was able to clean and lubricate the tracks. The seats adjust easily now. The passenger side would hardly move before.
