I always thought the T-10 in my late April 61 was original until I read recent posts and archives. I have owned the car for 35 years and it was all original except for having a replacement 870, 64 327/365 block. Even the flywheel is cast 3.29.61
Main case and side cover are cast iron, tailshaft is aluminum.
tail markings = 6.14.60, T10 - 7B, a raised "1"
main case = raised date 4-20, T10-1B, Q1, WG Div, "1" stamped on main case just forward of side cover, no date on side cover, stamped behind side coverWM80-2.
side cover is cast iron and has no markings
1- Any possibility this could this be the original trans for an April 61 car?
The 4-20 date and raised "1" was the reason I believed it was original to the car. The early tail shaft seemed a possibility given the manufacturing vagaries.
2- Is this a late 60 or an early 61 vette T-10?
3- Is this a vette trans?
Another T=10 in my 57 appears to be a 1960 vette trans but not sure.
main case - cast iron, T10-1B, 1Q, 5-13, WF10??
tail shaft - aluminum, T10-7B, 5-24-60, "1", WG div,
side cover is aluminum with no markings
3- assume this is a 1960 vette trans?
Joe
Joe
