Hi all,
I am having a problem of which I am not sure is the solenoid. When I hit the starter, the gear from the starter moves up against the edge of the teeth of the flywheel and basically just sits against it. If I keep the key on, sometimes the gear will slide on into the flywheel teeth at which time it spins flywheel spins nicely. On occasion, the gear slides in the first try, but not often.
Is the solenoid too weak to push the gears on in when there is not perfect correspondence between gear and teeth or what?
Bob
PS: Car is 1960.
Bob
PS: Car is 1960.
