C3 rear spring confusion - NCRS Discussion Boards
  • tom444634
    Weather finally getting warmer here so I decided to start the tear down of my rear suspension for a much needed overhaul. My rear spring has 9 leafs but they are all arched and there was a spacer between each spring. I thought there were two straight ones, leafs 8 and 9, and no spacer between 6 and 7.
    This came off of a fairly original 71 LS5 and judging by the amount of rust and grime, I don't know if this spring was ever off of the car. Past two owners confirmed that it wasn't and that takes it back to 1978. Don't know what happened before then......
    Photo is with the spacers removed.
    Ideas anyone?
    Tom
    Re: C3 rear spring confusion
    Tom-----
    I don't think that any spring of this configuration was ever originally used on a C3 Corvette. I wouldn't rule out the possibility that a "substitute" spring might have been used during a shortage and other-sourced springs used. I really, really doubt, though. GM had 2 sources for these springs as it was.
    The interesting thing about this spring is that it has the "upturned" leaf ends. Original springs used this configuration. However, from what I can see of the leaf ends in your photo, it does not appear to be the configuration the original exhibited. Rather, the configuration is much more similar to the reproduction springs sold be Eaton Detroit Spring which have come on the market in the last 10 years, or so. I didn't realize that there were any out there like this before that.
    • tom444634
      Thanks Joe. I always seem to get the odd ball things! This spring has definitly been on the car for a long time. Interesting thing is that the "up turns" you mention are wider on some leafs then on the others. Don't know if that means anything....
      I have more pics if anyone is interested.
      For what it is worth, the front springs are 3931826 code HV. This is a non-AC car built 9/70.
      • Gary B.
        • February 1, 1997
        • 6979
        Looks like a 75-77 10-leaf spring.
        Tom,
        Unless I'm mis-counting leaves in your photo, what you have there is a 10-leaf spring. Ten leaf, one-stage springs were used in 1975 (GM # 346906) and in 1976-1977 (GM # 362153), at which point my reseach data ends. These 10-leaf springs did indeed come with 9 liners, or 1 between each and every leaf.
        Gary
          Re: Looks like a 75-77 10-leaf spring.
          Gary-----
          Yes, I forgot about those. Also, I believe those springs became later GM SERVICE replacement springs for earlier models.
          • Dennis C.
            NCRS Past Judging Chairman
            • January 1, 1984
            • 2409
            Tom, You have an incredibly high membership #... *NM*
            • tom444634
              Gary,
              Thanks for the input. I suppose the spring got changed somewhere in the late 70's. Do you have any recommendations as to where I could get a correct spring for the car?
              Tom
              • tom444634
                Re: Tom, You have an incredibly high membership #.
                Yeah, how about that! I mis-typed when I was setting up my account and didn't catch it until it was too late. Thought it was kind of unique though....
                • Rob M.
                  • April 30, 2003
                  • 657
                  Tom,
                  I think the best source for a reproduction spring for your car will be from:
                  1555 Michigan, Detroit, MI 48216
                  phone 1-313-963-3839 fax 1-313-963-7047
                  Leaf Springs, Coil Springs, and Attaching Hardware manufactured by the experts for nearly ANY application. Over 166,000 makes and models covered. Made in America.
                  Good luck,
                  Rob
                  Rob
                  '66 327/300 Regional Top Flt
                  '08 6 speed coupe
                  • Philip C.
                    • December 1, 1984
                    • 1117
                    Re:high membership #AN NCRS ANOMALY.. *NM*
