66 big block oil pan bolt hole - NCRS Discussion Boards
  • Hal J.
    Infrequent User
    • June 30, 1986
    • 22
    Is there any other difference between an early 66 big block oil pan with a hole in the front that mates with the hole in the bottome of the timing chain cover vs 66+ or later big block oil pans without a hole (but w/ trap door and windage tray and supports)?
    I can not find a specific difference other than the hole and am contemplaing getting a used one w/o a hole and just drilling it.
    Thanks in advance for your input.
    Hal James #10081
    Re: 66 big block oil pan bolt hole
    Hal-----
    The hole is the only difference. However, some later pans do not have the 4 corner reinforcements spot welded to the pan. The reinforcements can be purchased in the restoration marketplace and added. There's no need to spot weld them; the bolts will hold them on just fine.
    • Hal J.
      Infrequent User
      • June 30, 1986
      • 22
      How about those drain plugs with an "A"
      Mr. Lucia: Thanks once again. I still have time to keep searching for an early oil pan before I am ready to re-install the engine, but as noted many different ways here, it is hard to justify $500 for some parts (like an oil pan).
      At the same time, how about $110 for a drain plug. How many of us have been digging through our bolt cans to find a 7/8 with the circle A???? I sure have. I figure if I find 2 that will bring the oil pan back to regular price for me!! I love trading car parts.
      Thanks again.
      Hal James 10081
