Reading the post back a few days ago Rob Musquetier was talking about his rear spring. He found out that his ended up to thick.(Eaton spring) I also bought a 9 leaf spring from Eaton and mine ended up to be 2and9/16" thick. Is this good or as Gary Beaupre said in the same thread it is to be 2.121". Will the ride hight be way off with the thickness difreance? Looking at the Production manual it looks like the ride hight should be 26.80". I took this off of UPC 0, sheet 13, Average Hights (R) conv-std suspension.
Allso what is the correct bolt lenght and is there one flat washer or two with a lock washer.
Any help would be great.
Thank You,
Rob
Thank You,
Rob
