When the lights are on, the switch stem on my '80 gets extremely hot. Tried a new switch--same problem. All lights work properly. Where do I go next before my car melts?
HOT Light Switch
Re: HOT Light Switch
More than likely you are driving with the dash lights turned down. The resistor for the dash lights is causing the heat. Remember 100-110 degrees is somewhat painful to touch for some people.
Another possibility, but you should have taken care of this when you replace the switch, is a loose connection. Check all connections on the switch to make sure that they are tight.Dick Whittington- Top
