John,
I'm in the process of having a new home built and have been in discussion with the builder re: underlayment for the garage floor to help prevent moisture and frost problems. I've read one or two of your posts relating to what was done for your garage a few years ago (some kind of vinyl moisture barrier followed by high density rigid foam with foil on both sides, then re-bar and mesh). When I inquired about having this done for mine, the builder's concrete contractor said he'd do the foam (they use out to four feet either side of all footings), but has never used foil-backed foam nor the vinyl sheeting and therefore was unwilling to do or warranty something he had no experience with. Could you explain why each layer is used so that I can try and convince him, or better yet, perhaps give me a contact number/e-mail for the concrete contractor you used so that maybe I can get the two to talk?
Sorry this isn't strictly Corvette related, but thanks!
grant
grant
