Thanks to all who gave me advice on the distributor. I got my original back on and timed. Is this position, the correct one for an original:
The vacuum advance is about 45 degrees right of centerline and the adjustment door is just about straight forward. There is also less bend in the tach cable then with the reversed dimple replacement. However to get 6 degrees BTDC the vacuum can is only about 1/8" off the coil.
I found that the original distributor moved about 14 degrees CW from the position of the reversed dimple distributor that it replaced. Here's the position of the reversed dimple distributor:
I guess if I had an automatic where the spec was 4 degrees retarded, the reversed dimple replacement would be the way to go. With my original and the position in the picture, there would be no way to get to 4 degrees retarded without going to the next gear tooth CCW or a full 28 degrees CCW. Maybe that's why they make some of these replacements with the gear reversed to the dimple.
I just took a run, and everything runs like brand new with my original distributor and original patent pending cap. So I think I'm ready for Flagstaff, here's the distributor I'll be coming with:
Having fun,
Jerry Fuccillo
#42179
Having fun,
Jerry Fuccillo
#42179
