c2 Blue white interior paint - NCRS Discussion Boards
  • Joe Gushen
    I've painted the dash on my 66 Corvette. It is a Blue and White interior. I actaully helped mix the paint it is correct, It calls for Nassau Blue flattened. I painted it and it appears dark. It does not match the dash pads, Are they supposed to match or it it ok to be darker. I actaully painted the dash twice because the first time I thought it was dark and maybe the paint was mixed wrong, same result the second time after I helped mix the PPG single stage paint. I started with stripped pieces and a light grey base both times. ANYONE?
  • Justin N.
    • February 1, 2004
    • 318
    Re: c2 Blue white interior paint
    Joe,
    My 67 #450 interior is the same color combo as yours. My dash, Pads, speaker cover, and console are all the same blue. They are all original and untouched from the assembly line.
    I tried one of the spray cans from a commmon vender to touch up and it was WAY off! The blue was more of an aqua/green color and I haulted all resto work there.
    Good Luck!
    Justin #41362
    [/IMG]
    • Justin N.
      • February 1, 2004
      • 318
      picture problems, try again *NM*
