Hi Everyone,
I just finished rebuilding my calipers and master cylinder and replacing all the rubber brake hoses. My last step is to install the master cylinder and then bleed the brakes. I know that bench bleeding the master cylinder is usually recommended but my question is, can I install the master cylinder, fill it with fluid and then use my Mity-Vac on the master cylinder bleeder screws to bleed the master cylinder? I figure that way I have a much smaller chance of getting brake fluid all over everything. I looked through the archives but didn't see this particular question addressed.
Thanks for your help - Matt
