Clutch type for 60 Vette - NCRS Discussion Boards
  • Bob Simard
    What do you guys recommend as a replacement clutch in a 60 Vette? Borg and Beck type or diaphram? I removed a three finger type and also have the godzilla spring installed. Thanks
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: Clutch type for 60 Vette
    Bob...
    Unless you plan to do something different with your '60, I would install a 3 finger type clutch...the godzilla works with it and a Multi-Finger (10 inch) may require the removal of the Godzilla spring, due to centrifugal force at high R.P.M., the clutch pedal could stay on the floor....this condition occurs in about 5% of applications...Best not to let it happen...
    • Jim D.
      • 2882
      Just installed a diaphram LUK clutch set-up and it works perfectly with my GODZILLA spring. I'd do it again in a heartbeat.
