Danger Will Robinson
The reason most tandem trailers have load range C tires is because the axles are rated for 3500 lbs only, AS ARE THE WHEELS. This gives a loaded trailer a max payload of 7000 lbs, with the 500 or 600 pounds on the hitch as insurance.
Previous posts have pointed out that a loaded enclosed trailer is already overweight with just a car in it. Upgrading the tires will provide no load carrying weight increase, as the rating is for the axles and brakes. (You do have brakes, right?) The only way to get correct payload when buying an enclosed trailer over 18ft long is to have the axles upgraded to at least 4500lb, and even better, to 6000lbs. My 24' United Expresslines enclosed trailer weighs 5000lbs empty. (A/C, Roof Platform, Cabinets, etc.) I had it built with 6k axles for a 12k payload. These axles take 8 lug 16" wheels, and I run the same tire as is on my Dooley. They are Michelin load range E at 80psi, and last forever.
Check the wheels on your trailer. If they are 5 lug they have a limited weight range. It should be stamped on the back.
I have the above 24', and a 40' gooseneck Pace American with 3 6000lb axles. I have towed all over the US, had a few flats (cut down 2 tires on my dooley during construction in Ohio - now carry 2 spares - had to leave the trailer with a '63 Cvt and a '64 big tank fuelie in a roadside area overnite) but never anything due to overloading or wrong size tires.
Marty McDonough
Marty McDonough
