Plastic plugs C2 - NCRS Discussion Boards
Plastic plugs C2
  • Joseph K.
    • March 1, 1980
    • 168
    Plastic plugs C2
    Does anyone know where on the body of a 65 coupe that 4 plastic semi-clear caplugs as installed? Am coming close to the end of putting car back together and I find these, with overspray from the previous paint job. Can anyone help? The plugs are about an inch in diameter............Thanks
  • Mike M.
    • May 31, 1974
    • 8365
    Re: Plastic plugs C2
    floor pan, under seats , takes a few. use them where you have about 1" diameter holes in floor pan. mike
    • Philip Whitaker Member# 2024
      It's been a while since I completed my restoration, but I rember some plastic plugs on the sides of the headlamp buckets.
      • Bob R.
        • June 30, 2002
        • 1595
        I believe the plugs in the floor are black, but when I removed my headlights the plastic plugs in those holes were clear.
        • Gary B.
          • February 1, 1997
          • 6979
          Headlight plugs
          I thought there were a total of 2 clear plastic plugs associated with the headlights; one on the outboard side of each bucket. No?
          Gary
          • Rob M.
            • June 30, 1999
            • 171
            Re: clear plugs
            I seem to recall clear plugs on the door sills covering body mounting bolts under the sill plate??
            My Project Pictures
            http://temp.corvetteforum.net/classics/l78vetteman/
            • Joseph K.
              • March 1, 1980
              • 168
              Re: clear plugs
              I'll bet they are from the headlight buckets as I removed buckets to be repainted. Thank you all for your thoughts.........Kirby
              • Stephen L.
                • May 31, 1984
                • 3148
                Re: Headlight plugs
                There are 2 plugs in each bucket, total 4. They plug the holes that are for access to the bolts that hold the buckets in place.
                • Mike G.
                  • January 1, 1991
                  • 418
                  The 1965 AIM does not show any plugs in the pivot assy, at least not that I can see. But maybe the pivots came with the plug already installed?
                  Anyone with an umolested '65 that can attest to these plugs being OEM?
                    I think they just forgot to show them in the A.I.M.; the headlight buckets were installed in the Body Shop, and the plastic plugs wouldn't have survived the heat of the Paint Shop prime oven if they were received as part of the raw bucket, removed for access to install the bolts, and re-installed.
