I pulled the high horse solid lifter camshaft fron an 3782870 327 block I am selling. I would like to identify it for future use. Numbers stamped on the rear end are: 611515A4; characters cast into the shaft are: CMC and CWC, D2, 30 ** K, and the last appears to be 6981 (only the six is clear). There is a yellow paint band also.
Do these numbers/charactors tell the grind, year of production, or intended use for this camshaft?
Thank you, george
Thank you, george
