Okay,
Facts: 1965 roadster - 327/365 hp 4 speed muncie.
Since replacing the throw out bearing last fall without completely removing the transmission didn't make the noise go away(see below) - I've now pulled the complete assembly out from the flywheel back.
We've discovered:
the pilot bearing was very dry and probably "gaulding" a little when the clutch was depressed.
It appears the incorrect clutch/pressure plate and throw out bearing combination was installed. The pressure plate iwas the diaphram type (10.4") and the "taller" throw out bearing was used. I had very little, if any, clutch adjustment which was also a sypmtom of the incorrect parts I believe.
I ordered a complete new Borg and Beck clutch kit from NAPA - with what i believe is the correct 3 lever pressure plate, 10.4" clutch, bronze pilot bearing and 1 1/4" tall throw out bearing.
Would welcome any comments re: anything else i should be looking for. The transmision front spline has a little wear we hope to clean up with emery cloth. Initial attempts to remove the pilot bearing have proven unsuccessful - looking for suggestions re: removal.
At least I believe I have now defined the cause of the problem ( which presented itself as a noise and vibration felt in the shifter when the clutch was depressed)_
Thanks all in advance.
Noel Kendall
We've discovered:
Noel Kendall
