Rally Rim Question - NCRS Discussion Boards
Rally Rim Question
  • larry linkous
    Rally Rim Question
    I have a set of rims that came off a 1969 427 Corvette years ago. However I am not sure if the are correct. It looks like K 10 or A 10 followed by a 9 on one side of the stem and and then a 8 on the other side of the stem. Also down below by the holes for the lug nuts there is a K or A and a 1 and a 0 underneath it. Anybody know what these are?/ Thanks as always for the help.
  • D S.
    • March 1, 2005
    • 1551
    Re: Rally Rim Question
    K=Kelsey, 1=Chevrolet, 0=1970, 9=September, 8=8th day of September. There should be an AZ stamped following the 8. AZ is for Corvette 15X8 wheel application.
    • Lyle24961
      Larry
      The numbers and letters you gave could have been on a 69. You should check the numbers near the valve stem to make sure what you posted is what you have as some of the information don,t look right to me.
      Lyle
      • Dave Riff
        Do you have a page with all the date codes? I have a few rims on three cars trying to find out what they are, all the spares are different. One says K139 21 AG, by the valve stem and in the center it says GM K k1 8
        another rims says K13 8 13 FW and in the center it says H2 k these are on my 1968 427 and i want to know what they are?
        • D S.
          • March 1, 2005
          • 1551
          K139 21 AG could instead be K138 21 AG because the center number is K-1-8 and AG is for a 1968 Corvette rally rim. Is this rim a 15 X 7?
          K13 8 13 FW is a Monte Carlo or El Camino application for the FW as I am told but could be wrong. August 13, 1973. Definitely not Corvette.
