Have a change to buy a 1964 Muncie M20.What parts would would I have to Change? Would stock linkage work? Thanks for any help Bob
1971 replace M21 with 1964-M20
Re: 1971 replace M21 with 1964-M20
I believe your 71 has a fine spline Muncie and the 64 will have a coarse. The counter shaft is smaller on the 64 then the 71. Why do you want to change? The 71 is a better unit unless it's "done"- Top
Unfortunately, all the '64 Mincie trans setups used the drivers side takeoff for the speedo gear, and the mainshaft is not setup with the longer register length used on later mainshafts to allow the trans to be built with ether the pass side or drivers side speedo output (location of the drive gear on the mainshaft must be changed) Also, the '71 uses bolt on shift levers, where the '64 is secured with a stud and nut setup. The parts are not directly interchangable as an exterior bolt-on.Bill Clupper #618- Top
