68-69 Front Turn Signal Question - NCRS Discussion Boards
  • Larry Kelly
    Are the front turn signal housings painted white on the inside? I took mine apart and cleaned them and both have (the remains) of a white finish on the inside. If that is original, was it just white paint? Also is there a way to tell original lenses from reproductions? I have seen lenses marked as repros but I have one lens with nothing on the edge and one with GM part numbers. Thanks.
  • Terry F.
    • September 30, 1992
    • 2061
    Re: 68-69 Front Turn Signal Question
    Original was painted bright white on inside. I suspect the one with the number is original. Terry
