1963 horn brackets - NCRS Discussion Boards
1963 horn brackets
  • Ray C.
    • June 30, 2001
    • 1132
    1963 horn brackets
    Could someone please provide me with pictures and dimensions for the mounting brackets for the high and low note horns for a 1963?
    email: ray63@rochester.rr.com
    Thanks for any help!
    Ray #36314
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Joe S.
    • July 31, 1999
    • 319
    Re: 1963 horn brackets
    This is a picture of a 63 Rad support (non Fuelie). Note the raised sections on either side down low and along the bottom. This is where the horns mount. If you have an AIM (Assembly Instruction Manual) it is cleanly identified in there as well as what horn goes on which side. If you don't have an AIM, they are available here through the online store and I'd recommend getting one.
    Joe's 63 FI Convertible
    • Ray C.
      • June 30, 2001
      • 1132
      Hi! Joe
      Thanks for the response! I am modifying a set of 1963 Impala horns. What I need is the brackets that mounts to the horn. The pictures and measurements that I am looking for is of the back of the horns. I hope these horns will get me by until I secure a set of correct horns; maybe at Carlisle.
      Ray
      Ray Carney
      • Joe S.
        • July 31, 1999
        • 319
        Ah,
        These are similar to what you are looking for. They came out of my 63 when I got it but are not correct. Original 63 Horns restored are not cheap but are available. If you need more info, drop me an email.
        You could easily make these out of a piece of flat steal from Home Depot. This would get you by until you get the real thing.
