C-1 front U-joint lub - NCRS Discussion Boards
  • Art B.
    • 333
    Every spring when I grease the chassis on my two C-1's, I also get the U-joints on the driveshaft. The front one is a hassle to get at because of the X-frame.
    How do the rest of you grease that one? There has to be a better way than the way I am doing it.
  • Mike M.
    • May 31, 1974
    • 8365
    Re: C-1 front U-joint lub
    various zirk fitting adaptors are available to insert between the fitting and the grease gun. without knowing the style of zirk in your u-joint, its difficult to advise style adaptor you need. if you are only putting a couple thousand miles a year on the vette, greasing it every 10 to 15 years is probably adequate.mike
    • Art B.
      • 333
      Thanks for the tip, Mike. Since I am now 65, one more time should do it!
