Warning: Undefined array key 5516 in .../vb/library/content.php on line 3508 Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737 Warning: Undefined array key "online" in .../vb/library/content.php on line 3522 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165 Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182 Warning: Undefined array key "posts" in .../vb/api/user.php on line 183 Warning: Undefined array key "posts" in .../vb/api/user.php on line 189 Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480 Warning: Undefined array key "userid" in .../vb/api/user.php on line 204 Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246 Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342 Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594 Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610 '66 power antenna cable source - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Anyone know of a source for a new power antenna cable?
  • Phil B.
    • Today
    Re: '66 power antenna cable source
    Rob - I had no luck in my search for a new cable. Finally had OEM Glass in I think Minn. rebuild entire unit. Cost was around $550 and they did a great job. They do not sell parts and pretty much regardless of condition the cost is the same.
    • Ken Edmunds
      OEM GLASS Bloomington Il 800 283 2122
      • Rob A.
        • December 1, 1991
        • 2126
        Eric,
        Considering I'm not interested in cosmetic restoration of my antenna, $550 is a lot of $. I'll try to find out what other models have an antenna I can use for a "donor" cable. Southern CA should be a good place to find one not rusted out, if that's possible.
        • Greg T.
          • January 1, 2004
          • 136
          I can provide you with a cable. We'll have to discuss what type of fitting your solid mast section uses. Some are swaged and others use a #3-38 thread. E-mail me at gthompson49@kc.rr.com if you're interested.
