Headlight bucket motor for C2 - NCRS Discussion Boards
  • don 42616
    Hi all,
    My left bucket motor will not go down more then 1/2 way. Then rotating wheel also is stuck at that position. It will go all the way up.
    I searched the archives . All the info deals with motor rebuild. I have a GREAT site with color photos . I think I can do the rebuild following the pictures. Problem is no threds on removing motor. How many bolts, Etc.
    I enclosed the rebuild site in case anybody wants it. Thanks, Don
    http://www.c2registry.org/downloads/...ht%20Motor.pdf
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Headlight bucket motor for C2
    Removing the motor is not that difficult. There is 1 small hex head bolt it hold a wire in place,it has a 1/4" head and is very short, then there is a clip on the end of the motor that snaps off. Don't loose that short bolt. If you replace it with a longer one you could damage the motor.
    Reinstall is more difficult because you're working upside down. A mirror helps. Install a pin ot bolt in your hood prop so it won't fall on you.
