Who offers the best aftermarket '67 antenna - NCRS Discussion Boards
  • Scott Marzahl
    Would anyone have a recommendation for the best quality reproduction antenna available for a '67.
    Thanks much.
    Scott
  • Scott Marzahl
    Addendum: aftermarket '67 antenna
    I should have said antenna assembly, body, mounting nut, antenna shaft with ball, etc.
    • Peter L.
      • May 31, 1983
      • 1930
      Re: Addendum: aftermarket '67 antenna
      Scott - It's a challenge for what one would think is a relatively uncomplicated item. My experience is that currently no one has a replacement antenna mast (base specifically and sometimes the ball because it's the small one and some have a shaft that is not taper "enough") that is not a readily detectibly different from the original 67 Corvette antenna. The good news is in general the mounting pieces are not to bad. Pete
