65 350HP no AC Firewall Grommets Help
  • Dick Gutman (13180)
    • June 1, 1988
    • 681
    For my 65 350HP No AC car. I searched the archives on this subject. Looked in my AIM. Looked at some video and pictures of 65's I took of . My speedo and tach cable exited (as found) through the same hole/grommet in the firewall. The hole facing the pass. side not the front by wiper motor. AIM show speedo exiting below clutch arm. Do the oil line and tach cable exit through the same grommet? Any help is appreciated. Dick Gutman
  • John Hinckley (29964)
    Re: 65 350HP no AC Firewall Grommets Help
    Dick -
    The speedo cable routing shown in UPC 12 below the clutch rod is for the base car (3-speed manual), which has the speedo cable on the driver's side of the transmission; the routing for the 4-speed (speedo on the passenger side of the transmission) is shown in Section M20, sheet 4, and the speedo and tach cable go through the same hole in the side of the recess for the wiper motor.
    The oil pressure line goes through a second hole, below the wiper motor, with the wiper motor wiring.
      • June 1, 1988
      • 681
      Thanks for clearing that up John. You're a great asset to this forum and Corvette Forum. By the way, I am a new subscriber to Corvette Enthusiast. Keep up the great work. Thanks! Dick Gutman
