Fan Clutch Rotation Question... - NCRS Discussion Boards
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    In this particular SBC application, I am using a GM serpentine belt drive which utilizes a reverse rotation water pump and fan. If I desire to add a fan clutch, will the reverse rotation be a factor, or will the clutch not care which way it is turning and function properly in either direction. If this will work, how about opinions on whether this is a worthwhile addition. Thanks, Dennis
  • David M.
    • September 30, 2004
    • 515
    Re: Fan Clutch Rotation Question...
    You will need to get a fan and fan clutch designed for reverse rotation
      • 15573
      Dennis
      Can you not use an electric fan? Properly controlled electric fans can be very efficient.
      • Dennis C.
        • January 1, 1984
        • 2409
        Currently...
        ...the installation as described is in place on the "Carvette", minus the possibility of adding a fan clutch - thus the question about the clutch. Maybe I should have gone with the electric fan setup, but for now I'm stuck with my earlier decision.
