1960 hood release problem
Re: 1960 hood release problem
I haven't done it recently, but removing the splash shield should give you enough room to get up to the latch and activate it from the bottom.Bill Clupper #618- Top
Also, that is why the wire should be bent at a right angle right after it passes through the stop. If the stop screw comes loose, the cable willnot pull out of the stop and will still actuate the latch. This is the way the factory did it, and many judges look for this bend in the wire.
Regards, John McGraw- Top
