C1 intake manifold help - NCRS Discussion Boards
  • John C.
    • September 30, 2001
    • 130
    Do the bolts need to be to torqued down,if so what is the PSI thanks
  • William C.
    • May 31, 1975
    • 6037
    Re: C1 intake manifold help
    Yes, there is a sequence and torque is 25-35 foot-lbs. the torque sequence starts at the center bolts (exaust crossover) and works clockwise around the four bolts that enclose the exhaust crossover, then across the engine from side to side 2 bolts per side toward the rear of the engine and finally to the front using the same paired pattern use incermantal steps and run over the sequence a final time to even all torques.
    Bill Clupper #618
      john and Bill-----
      ....and a simplified diagram with the sequence depicted by numbers can be found in most Chevrolet or Corvette factory service manuals as well as most "generic" manuals like Chiltons, etc.
